We are thrilled to announce a major enhancement to Visual Paradigm VPasCode, Visual Paradigm’s unified diagram-as-code platform. Today, we are expanding our data visualization capabilities by introducing full native support for JSONL (JSON Lines) and NDJSON (Newline Delimited JSON).
Whether you are debugging server logs, analyzing distributed telemetry, or working with microservice streams, our updated free JSONL editor and online JSONL diagram tool make reading and understanding complex structured data effortless.
What is VPasCode?
If you are new to VPasCode, it is an all-in-one diagram-as-code solution designed to bridge the gap between text definitions and visual architecture. Instead of manually drawing shapes, engineers, analysts, and system designers can write or paste standard markup, scripts, and structured data formats to render real-time, interactive diagrams.
VPasCode supports a wide array of diagram scripting DSLs and languages, including:
- Diagram & Visualization Tools: PlantUML, Mermaid, Graphviz, Markmap, ECharts
- Structured Data Formats: JSON, NDJSON / JSONL, YAML, XML, CSV, TOML
- Database Languages: SQL
- Programming Languages: Java, TypeScript, Go, Rust, C#, Python, C, C++, PHP, Ruby, Scala, Zig, Kotlin, Swift, Elixir
With support for comprehensive modeling frameworks—such as Sequence, Class, State, Activity, ArchiMate, C4, Gantt, Mind Maps, and ERD diagrams—VPasCode serves as a single workspace for all your technical visualization needs.
Why Support JSONL (NDJSON)?
JSON Lines (JSONL) and Newline Delimited JSON (NDJSON) have become standard formats for modern data pipelines, event-driven architectures, and high-throughput logging system outputs. Because each line represents a distinct, valid JSON object, processing large datasets line-by-line is efficient for systems—but often painful for humans trying to grasp the big picture.
By using VPasCode as an online JSONL diagram tool, you can transform dense cloud events and unstructured streams into clear, readable visual diagrams instantly.
How JSONL Visualization Works in VPasCode
Visualizing your event streams and structured datasets with our free JSONL editor is fast and straightforward. When you open the editor workspace, you get a split-screen interface: your editable code sits on the left, and your dynamic diagram renders on the right.
Step-by-Step Example: Visualizing Cloud Event Logs
Imagine you are inspecting a sequence of e-commerce checkout events stored in JSONL format:
{"eventId":"e-1001","source":"web/checkout","type":"order.placed","time":"2025-01-15T10:00:00Z","data":{"orderId":"o-501","amount":129.99,"currency":"USD"}}
{"eventId":"e-1002","source":"web/checkout","type":"order.paid","time":"2025-01-15T10:01:30Z","data":{"orderId":"o-501","paymentId":"pay-3a2b","method":"credit_card"}}
{"eventId":"e-1003","source":"warehouse/shipping","type":"order.shipped","time":"2025-01-15T11:30:00Z","data":{"orderId":"o-501","carrier":"UPS","tracking":"1Z999AA10123456784"}}
{"eventId":"e-1004","source":"web/checkout","type":"order.placed","time":"2025-01-15T12:15:00Z","data":{"orderId":"o-502","amount":49.99,"currency":"USD"}} When you paste this NDJSON block directly into our editor, VPasCode parses each line, extracts key relationships, attributes, and data structures, and draws an interactive diagram on the canvas in real time.
Key Features of Our Online JSONL Diagram Tool
Beyond live rendering, our free JSONL editor includes a suite of interactive features built to speed up your technical workflows:
- Bidirectional Code Navigation: Click on any shape or node in your rendered visual diagram, and the editor will automatically jump to and highlight the exact corresponding line in your JSONL/NDJSON source code.
- One-Click Code Formatting: Messy or minified lines? Format your JSON lines into clean, standardized code with a single click.
- Multiple Diagram Themes: Customize the aesthetic look and feel of your diagrams to suit dark mode, presentations, or documentation guidelines.
- Flexible Image Exporting: Download high-resolution vector diagrams as SVG files for scaling, or grab fast PNG renders for quick reporting.
- Instant Clipboard Copying: Copy generated visual diagrams straight to your system clipboard for instant pasting into slack channels, bug reports, or emails.
- No-Login Sharing: Generate lightweight share URLs to send full interactive diagrams directly to teammates. Recipients can inspect and edit the diagram right away without needing an account.
Smart AI Capabilities & Ecosystem Integration
In addition to core editing features, VPasCode includes powerful intelligent capabilities to streamline your technical workflows:
- Automatic Format Detection: Simply paste your code, and VPasCode automatically identifies whether you are using PlantUML, Mermaid, SQL, JSON, or JSONL, rendering the diagram without requiring manual mode switches.
- AI Code Error Fixing: Stuck on a syntax error? Hit ‘Fix by AI’ to auto-correct broken syntax while receiving a transparent, side-by-side code diff explaining what went wrong so you can learn on the go.
- AI Diagram Translation: Natively translate labels, key names, and strings inside your visual diagrams across multiple languages in seconds.
- OpenDocs Integration: Seamlessly send your NDJSON and diagram models directly into Visual Paradigm OpenDocs to generate comprehensive technical documentation.
Try the Free JSONL Editor Today
Diagram creation, real-time previewing, formatting, sharing, and image exports are completely free for everyone. Advanced AI capabilities like AI error fixing and AI translation are integrated for subscribers of Visual Paradigm Online Combo Edition (and above) or active maintenance holders of Visual Paradigm Desktop Professional Edition.
Ready to visualize your structured data logs and NDJSON streams instantly?
