{"name":"Visual Paradigm Product Updates German","description":"","url":"https:\/\/updates.visual-paradigm.com\/de","home":"https:\/\/updates.visual-paradigm.com\/de","gmt_offset":"8","timezone_string":"","page_for_posts":0,"page_on_front":10,"show_on_front":"page","namespaces":["oembed\/1.0","featured-image-from-url\/v2","featured-image-from-url\/v1","msls\/v1","yoast\/v1","kb-mailerlite\/v1","kb-getresponse\/v1","kb-fluentcrm\/v1","kbp\/v1","kb-lottieanimation\/v1","kb-vector\/v1","kb-design-library\/v1","kb-image-picker\/v1","metaslider\/v1","astra\/v1","elementor\/v1\/documents","elementor\/v1","elementor-ai\/v1","nps-survey\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/updates.visual-paradigm.com\/de\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/oembed\/1.0\/proxy"}]}},"\/featured-image-from-url\/v2":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2"}]}},"\/featured-image-from-url\/v2\/metadata_counter_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metadata_counter_api"}]}},"\/featured-image-from-url\/v2\/enable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/enable_fake_api"}]}},"\/featured-image-from-url\/v2\/disable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/disable_fake_api"}]}},"\/featured-image-from-url\/v2\/data_clean_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/data_clean_api"}]}},"\/featured-image-from-url\/v2\/run_delete_all_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/run_delete_all_api"}]}},"\/featured-image-from-url\/v2\/disable_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/disable_default_api"}]}},"\/featured-image-from-url\/v2\/none_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/none_default_api"}]}},"\/featured-image-from-url\/v2\/load-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/load-sizes-api"}]}},"\/featured-image-from-url\/v2\/reset-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/reset-sizes-api"}]}},"\/featured-image-from-url\/v2\/save-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/save-sizes-api"}]}},"\/featured-image-from-url\/v2\/pre_deactivate":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/pre_deactivate"}]}},"\/featured-image-from-url\/v2\/feedback":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/feedback"}]}},"\/featured-image-from-url\/v2\/deactivate_itself":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/deactivate_itself"}]}},"\/featured-image-from-url\/v2\/rest_url_api":{"namespace":"featured-image-from-url\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/rest_url_api"}]}},"\/featured-image-from-url\/v2\/metain":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metain"}]}},"\/featured-image-from-url\/v2\/metaout":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metaout"}]}},"\/featured-image-from-url\/v1":{"namespace":"featured-image-from-url\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v1"}]}},"\/featured-image-from-url\/v1\/url\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/featured-image-from-url\/v2\/create_thumbnails_list":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/create_thumbnails_list"}]}},"\/featured-image-from-url\/v2\/sign_up":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/sign_up"}]}},"\/featured-image-from-url\/v2\/connected":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/connected"}]}},"\/featured-image-from-url\/v2\/reset_credentials":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/reset_credentials"}]}},"\/featured-image-from-url\/v2\/list_all_su":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_su"}]}},"\/featured-image-from-url\/v2\/list_all_fifu":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_fifu"}]}},"\/featured-image-from-url\/v2\/list_all_media_library":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_media_library"}]}},"\/featured-image-from-url\/v2\/list_daily_count":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_daily_count"}]}},"\/featured-image-from-url\/v2\/delete":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/delete"}]}},"\/featured-image-from-url\/v2\/cancel":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cancel"}]}},"\/featured-image-from-url\/v2\/payment_info":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/payment_info"}]}},"\/featured-image-from-url\/v2\/cloud_upload_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_upload_auto"}]}},"\/featured-image-from-url\/v2\/cloud_delete_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_delete_auto"}]}},"\/featured-image-from-url\/v2\/cloud_hotlink":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_hotlink"}]}},"\/featured-image-from-url\/v2\/debug-slug\/(?P<slug>[a-z0-9-_]+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-postmeta\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-posts\/(?P<id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-metain":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/debug-metain"}]}},"\/featured-image-from-url\/v2\/debug-metaout":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/debug-metaout"}]}},"\/featured-image-from-url\/v2\/debug-log\/(?P<type>(cloud|plugin))":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":true},"lines":{"required":false}}}]},"\/msls\/v1":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"msls\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1"}]}},"\/msls\/v1\/duplicate-post":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true},"target_locale":{"required":true},"_elementor_data":{"required":false},"_yoast_wpseo_title":{"required":false},"_yoast_wpseo_metadesc":{"required":false},"update_existing":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/duplicate-post"}]}},"\/msls\/v1\/posts-without-translation\/(?P<target_locale>[a-zA-Z0-9_-]+)":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"target_locale":{"required":true},"post_type":{"default":"post","required":false}}}]},"\/msls\/v1\/posts-missing-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"default":"publish","required":false},"post_type":{"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/posts-missing-translations"}]}},"\/msls\/v1\/fix-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"source_post_id":{"required":true},"source_blog_id":{"required":true},"target_post_id":{"required":true},"target_blog_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-taxonomies"}]}},"\/msls\/v1\/fix-all-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-all-taxonomies"}]}},"\/msls\/v1\/fix-post-parents":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"verbose":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-post-parents"}]}},"\/msls\/v1\/fix-post-dates":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-post-dates"}]}},"\/msls\/v1\/outdated-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"default":"all","required":false},"status":{"default":"publish","required":false},"languages":{"default":"","required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/outdated-translations"}]}},"\/msls\/v1\/blog-language-map":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/msls\/v1\/blog-language-map"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/workouts"}]}},"\/kb-mailerlite\/v1":{"namespace":"kb-mailerlite\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-mailerlite\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-mailerlite\/v1"}]}},"\/kb-mailerlite\/v1\/get":{"namespace":"kb-mailerlite\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"apikey":{"description":"Der API Schl\u00fcssel f\u00fcr den Mailerlite Account.","type":"string","required":false},"endpoint":{"description":"Realisierbarer Endpunkt f\u00fcr API-Call.","type":"string","required":false},"queryargs":{"description":"Query-Argumente f\u00fcr die URL.","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-mailerlite\/v1\/get"}]}},"\/kb-getresponse\/v1":{"namespace":"kb-getresponse\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-getresponse\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-getresponse\/v1"}]}},"\/kb-getresponse\/v1\/get":{"namespace":"kb-getresponse\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"endpoint":{"description":"Realisierbarer Endpunkt f\u00fcr API-Call.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-getresponse\/v1\/get"}]}},"\/kb-fluentcrm\/v1":{"namespace":"kb-fluentcrm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-fluentcrm\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-fluentcrm\/v1"}]}},"\/kb-fluentcrm\/v1\/get":{"namespace":"kb-fluentcrm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"endpoint":{"description":"Realisierbarer Endpunkt f\u00fcr API-Call.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-fluentcrm\/v1\/get"}]}},"\/kbp\/v1":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kbp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kbp\/v1"}]}},"\/kbp\/v1\/post-query":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Anzahl der ausgegebenen Ergebnisse","type":"number","default":25,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"description":"Beschr\u00e4nke die Ergebnisse auf Elemente eines bestimmten Beitragstyps.","type":"string","required":false},"include":{"description":"Beitr\u00e4ge nach ID einbeziehen","type":"array","required":false},"query":{"description":"Definiere Abfrage-Typ","type":"string","required":false},"order":{"description":"Definiere Abfrage-Reihenfolge","type":"string","required":false},"order_by":{"description":"Definiere Abfrage-Reihenfolge nach","type":"string","required":false},"allow_sticky":{"description":"Erlaube oben gehalten in der Abfrage","type":"boolean","required":false},"exclude":{"description":"Kategorie ausschlie\u00dfen","type":"string","required":false},"offset":{"description":"Anzahl der zu verschiebenden Elemente in der Abfrage.","type":"number","default":0,"required":false},"post_id":{"description":"Die aktuelle Beitrags-ID","type":"string","required":false},"custom_tax":{"description":"Bei Verwendung individueller Taxonomie anhaken","type":"boolean","required":false},"tax_type":{"description":"Definiere Abfrage-Reihenfolge nach","type":"string","required":false},"category":{"description":"Beitrags-Kategorie einschlie\u00dfen","type":"string","required":false},"tags":{"description":"Beitrags-Tags einschlie\u00dfen","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kbp\/v1\/post-query"}]}},"\/kbp\/v1\/taxonomies-select":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Seite der Ergebnisse, die zur\u00fcckgegeben werden sollen.","type":"number","default":1,"required":false},"per_page":{"description":"Anzahl der ausgegebenen Ergebnisse","type":"number","default":25,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"source":{"description":"Die Quelle des Inhalts.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kbp\/v1\/taxonomies-select"}]}},"\/kbp\/v1\/term-select":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Seite der Ergebnisse, die zur\u00fcckgegeben werden sollen.","type":"number","default":1,"required":false},"per_page":{"description":"Anzahl der ausgegebenen Ergebnisse","type":"number","default":25,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"source":{"description":"Die Quelle des Inhalts.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kbp\/v1\/term-select"}]}},"\/kb-lottieanimation\/v1":{"namespace":"kb-lottieanimation\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-lottieanimation\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-lottieanimation\/v1"}]}},"\/kb-lottieanimation\/v1\/animations\/(?P<id>[\\a-zA-Z0-9]+)":{"namespace":"kb-lottieanimation\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/kb-lottieanimation\/v1\/animations":{"namespace":"kb-lottieanimation\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-lottieanimation\/v1\/animations"}]}},"\/kb-vector\/v1":{"namespace":"kb-vector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-vector\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-vector\/v1"}]}},"\/kb-vector\/v1\/vectors":{"namespace":"kb-vector\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-vector\/v1\/vectors"}]}},"\/kb-design-library\/v1":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-design-library\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1"}]}},"\/kb-design-library\/v1\/get":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get"}]}},"\/kb-design-library\/v1\/get_all_items":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_all_items"}]}},"\/kb-design-library\/v1\/get-all-ai":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get-all-ai"}]}},"\/kb-design-library\/v1\/get_remaining_jobs":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_remaining_jobs"}]}},"\/kb-design-library\/v1\/get_library":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_library"}]}},"\/kb-design-library\/v1\/get_library_categories":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_library_categories"}]}},"\/kb-design-library\/v1\/get_connection":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_connection"}]}},"\/kb-design-library\/v1\/get_local_contexts":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_local_contexts"}]}},"\/kb-design-library\/v1\/get_verticals":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_verticals"}]}},"\/kb-design-library\/v1\/get_keywords":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_keywords"}]}},"\/kb-design-library\/v1\/get_initial_jobs":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_initial_jobs"}]}},"\/kb-design-library\/v1\/get_search_query":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_search_query"}]}},"\/kb-design-library\/v1\/get_images":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_images"}]}},"\/kb-design-library\/v1\/get_image_collections":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_image_collections"}]}},"\/kb-design-library\/v1\/get_pattern_content":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_pattern_content"}]}},"\/kb-design-library\/v1\/process_pattern":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/process_pattern"}]}},"\/kb-design-library\/v1\/process_images":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/process_images"}]}},"\/kb-design-library\/v1\/get_remaining_credits":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/get_remaining_credits"}]}},"\/kb-design-library\/v1\/reset":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence-Lizenzschl\u00fcssel.","type":"string","required":false},"api_email":{"description":"Kadence-Lizenz-E-Mail.","type":"string","required":false},"product_id":{"description":"Kadence-Lizenz-Produkt-ID.","type":"string","required":false},"pattern_type":{"description":"Pattern Type","type":"string","required":false},"pattern_style":{"description":"Pattern Style","type":"string","required":false},"pattern_id":{"description":"Pattern ID","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/reset"}]}},"\/kb-image-picker\/v1":{"namespace":"kb-image-picker\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-image-picker\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-image-picker\/v1"}]}},"\/kb-image-picker\/v1\/process_images":{"namespace":"kb-image-picker\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"image_type":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"string","required":false},"image_sizes":{"description":"Der Bildtyp, der zur\u00fcckgegeben werden soll","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-image-picker\/v1\/process_images"}]}},"\/kb-design-library\/v1\/handle_event":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"event_label":{"description":"The Event Label","type":"string","required":false},"event_data":{"description":"The Event Data","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/kb-design-library\/v1\/handle_event"}]}},"\/metaslider\/v1":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"metaslider\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1"}]}},"\/metaslider\/v1\/slideshow\/all":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/all"}]}},"\/metaslider\/v1\/slideshow\/list":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/list"}]}},"\/metaslider\/v1\/slideshow\/single":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/single"}]}},"\/metaslider\/v1\/slideshow\/legacy":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/legacy"}]}},"\/metaslider\/v1\/slideshow\/preview":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/preview"}]}},"\/metaslider\/v1\/slideshow\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/save"}]}},"\/metaslider\/v1\/slideshow\/delete":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/delete"}]}},"\/metaslider\/v1\/slideshow\/duplicate":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/duplicate"}]}},"\/metaslider\/v1\/slideshow\/search":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/search"}]}},"\/metaslider\/v1\/slideshow\/export":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/export"}]}},"\/metaslider\/v1\/slideshow\/import":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/slideshow\/import"}]}},"\/metaslider\/v1\/themes\/all":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/themes\/all"}]}},"\/metaslider\/v1\/themes\/custom":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/themes\/custom"}]}},"\/metaslider\/v1\/theme\/customization":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/theme\/customization"}]}},"\/metaslider\/v1\/themes\/set":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/themes\/set"}]}},"\/metaslider\/v1\/import\/images":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/import\/images"}]}},"\/metaslider\/v1\/import\/others":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/import\/others"}]}},"\/metaslider\/v1\/tour\/status":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/tour\/status"}]}},"\/metaslider\/v1\/settings\/user\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/user\/save"}]}},"\/metaslider\/v1\/settings\/user":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/user"}]}},"\/metaslider\/v1\/settings\/global\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/global\/save"}]}},"\/metaslider\/v1\/settings\/global\/single\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/global\/single\/save"}]}},"\/metaslider\/v1\/settings\/single":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/single"}]}},"\/metaslider\/v1\/settings\/global":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/global"}]}},"\/metaslider\/v1\/settings\/slideshow\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/slideshow\/save"}]}},"\/metaslider\/v1\/settings\/slideshow\/save-single":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/slideshow\/save-single"}]}},"\/metaslider\/v1\/settings\/slideshow\/defaults":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/slideshow\/defaults"}]}},"\/metaslider\/v1\/settings\/slideshow\/defaults\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/slideshow\/defaults\/save"}]}},"\/metaslider\/v1\/images\/ids-from-filenames":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/images\/ids-from-filenames"}]}},"\/metaslider\/v1\/settings\/pro":{"namespace":"metaslider\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/pro"}]}},"\/metaslider\/v1\/settings\/pro\/save":{"namespace":"metaslider\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/metaslider\/v1\/settings\/pro\/save"}]}},"\/astra\/v1":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"astra\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/astra\/v1"}]}},"\/astra\/v1\/admin\/settings":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/astra\/v1\/admin\/settings"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","container"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/nps-survey\/v1":{"namespace":"nps-survey\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nps-survey\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1"}]}},"\/nps-survey\/v1\/rating":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1\/rating"}]}},"\/nps-survey\/v1\/dismiss-nps-survey":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1\/dismiss-nps-survey"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Den Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen begrenzen.","type":"array","items":{"type":"string","enum":["image","video","audio","text","application"]},"required":false},"mime_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, an der der Zuschnitt beginnen soll, in Prozent der Bildbreite.","type":"number"},"top":{"description":"Vertikale Position von oben, an der der Zuschnitt beginnen soll, in Prozent der Bildh\u00f6he.","type":"number"},"width":{"description":"Die Breite des Zuschnitts in Prozent der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts in Prozent der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Bereich in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision der globalen Stile.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der globalen Stile-Konfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stilvariante.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stilvariante, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftschnitt-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/e-floating-buttons"}]}},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_form":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_form"}]}},"\/wp\/v2\/kadence_form\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/kadence_form\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_form\/auto-draft"}]}},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_navigation"}]}},"\/wp\/v2\/kadence_navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/kadence_navigation\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_navigation\/auto-draft"}]}},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_header":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_header"}]}},"\/wp\/v2\/kadence_header\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/kadence_header\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_header\/auto-draft"}]}},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/releases":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"product":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie product zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie product zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"product-area":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie product-area zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"product-area_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie product-area zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"version":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie version zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"version_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie version zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"release-type":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie release-type zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"release-type_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie release-type zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"product":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"product-area":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product-area zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"version":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie version zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"release-type":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie release-type zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/releases"}]}},"\/wp\/v2\/releases\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"product":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"product-area":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product-area zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"version":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie version zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"release-type":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie release-type zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/releases\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/releases\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/releases\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"product":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"product-area":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie product-area zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"version":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie version zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"release-type":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie release-type zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/releases\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_lottie":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_lottie"}]}},"\/wp\/v2\/kadence_lottie\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_vector":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/kadence_vector"}]}},"\/wp\/v2\/kadence_vector\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/product"}]}},"\/wp\/v2\/product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/product-area":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/product-area"}]}},"\/wp\/v2\/product-area\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/version":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/version"}]}},"\/wp\/v2\/version\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/release-type":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/release-type"}]}},"\/wp\/v2\/release-type\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"default":"asc","description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder eine einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","e-floating-buttons":"e-floating-buttons","elementor_library":"elementor_library","kadence_form":"kadence_form","kadence_navigation":"kadence_navigation","kadence_header":"kadence_header","releases":"releases","kadence_lottie":"kadence_lottie","kadence_vector":"kadence_vector"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Kommentare ausschlie\u00dft, die einer bestimmten Benutzer-ID zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Sicherstellen, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf einen oder mehrere Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","e-floating-buttons","elementor_library","releases","category","post_tag","product","product-area","version","release-type","any"],"type":"string"},"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"Die ID des Beitragskontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"kadence_blocks_config_blocks":{"title":"","description":"Kadence Block-Standards konfigurieren","type":"string","required":false},"kadence_blocks_settings_blocks":{"title":"","description":"Konfiguriere Kadence Bl\u00f6cke Sichtbarkeitseinstellungen","type":"string","required":false},"kadence_blocks_settings":{"title":"","description":"Konfiguriere Kadence Block Einstellungen","type":"string","required":false},"kadence_blocks_prophecy":{"title":"","description":"Config Kadence Block Prophecy AI","type":"string","required":false},"kadence_blocks_colors":{"title":"","description":"Konfiguriere Kadence Bl\u00f6cke Farbpalette","type":"string","required":false},"kadence_blocks_global":{"title":"","description":"Konfiguriere Kadence Bl\u00f6cke globale Einstellungen","type":"string","required":false},"kadence_blocks_recaptcha_site_key":{"title":"","description":"Google reCaptcha Website Key","type":"string","required":false},"kadence_blocks_recaptcha_secret_key":{"title":"","description":"Google reCaptcha Secret Key","type":"string","required":false},"kadence_blocks_recaptcha_language":{"title":"","description":"Google reCaptcha Sprache","type":"string","required":false},"kadence_blocks_turnstile_site_key":{"title":"","description":"Cloudflare Turnstile Site Key","type":"string","required":false},"kadence_blocks_turnstile_secret_key":{"title":"","description":"Cloudflare Turnstile Secret Key","type":"string","required":false},"kadence_blocks_hcaptcha_site_key":{"title":"","description":"hCaptcha Turnstile Site Key","type":"string","required":false},"kadence_blocks_hcaptcha_secret_key":{"title":"","description":"hCaptcha Secret Key","type":"string","required":false},"kadence_blocks_mailerlite_api":{"title":"","description":"MailerLite API Schl\u00fcssel","type":"string","required":false},"kadence_blocks_google_maps_api":{"title":"","description":"Google Maps API Key","type":"string","required":false},"kadence_blocks_cloud":{"title":"","description":"Kadence Block-Cloud konfigurieren","type":"string","required":false},"kadence_blocks_header_notice_dismissed":{"title":"","description":"Is Kadence header notice dismissed","type":"boolean","required":false},"kadence_blocks_wire_subscribe":{"title":"","description":"Abonniere die Wireframe-Bibliothek","type":"boolean","required":false},"kadence_blocks_convertkit_api":{"title":"","description":"ConvertKit API Key","type":"string","required":false},"kadence_blocks_activecampaign_api_key":{"title":"","description":"ConvertKit API Key","type":"string","required":false},"kadence_blocks_activecampaign_api_base":{"title":"","description":"ConvertKit API Key","type":"string","required":false},"kadence_blocks_header_popover_tutorial_complete":{"title":"","description":"Mark the Header popover tutorial Complete","type":"boolean","required":false},"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"Der WordPress-Lokalisierungscode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Homepage angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaubt Personen, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanz-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Eine alphanumerische Kennung f\u00fcr die Men\u00fcposition.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Eingabeparameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie begrenzen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":117,"site_icon":113,"site_icon_url":"https:\/\/updates.visual-paradigm.com\/de\/wp-content\/uploads\/sites\/9\/2025\/11\/cropped-favicon-1.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media\/117"},{"embeddable":true,"type":"site_icon","href":"https:\/\/updates.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media\/113"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
